ContextCapture: Difference Between Tie Points and Control Points
Question:
What is the difference between Tie Points and Control Points?
Answer:
A tie point corresponds to pixels in two or more different photographs, where these pixels represent the projection of the same physical point in the scene. ContextCapture can automatically generate a large number of automatic tie points during the aerotriangulation process. User tie points can also be entered a priori from a dedicated interface to help aerotriangulation.
Control points are optional positioning data used during the aerotriangulation of the block. Adding control points to a block makes it possible to accurately georeference it and avoids long-range metric distortion.
