| Version(s): | 08.11.09+ |
| Area: | Cross Sections |
Question:
Can you combine the photo mesh with a topo survey to create a more accurate mesh?
Answer:
Yes - It is recommended that you place targets that will be visible in the photographs. You can then shoot survey data on these targets. To link the survey data and photographs, create tie-in points between the photographs and survey points using the targets.
