Key-in |
Description |
mrmesh clipplus |
Opens the Clip Reality Mesh tool. |
mrmesh clipplus block |
Selects the block method in the Clip Reality Mesh tool. |
mrmesh clipplus oriblock |
Selects the oriented block method in the Clip Reality Mesh tool. |
mrmesh clipplus oriblockbyaxis |
Selects the oriented block by axis method in the Clip Reality Mesh tool. |
mrmesh clipplus box |
Selects the box method in the Clip Reality Mesh tool. |
mrmesh clipplus polygon |
Selects the polygon method in the Clip Reality Mesh tool. |
mrmesh clipplus element |
Selects the element method in the Clip Reality Mesh tool. |
mrmesh clipplus view |
Selects the view method in the Clip Reality Mesh tool. |
mrmesh clipplus mode boundary |
Selects the boundary mode in the Clip Reality Mesh tool. |
mrmesh clipplus mode mask |
Selects the mask mode in the Clip Reality Mesh tool. |
mrmesh clipplus applytoall on |
Toggles ON the Apply to all option of the Clip Reality Mesh tool. |
mrmesh clipplus applytoall off |
Toggles OFF the Apply to all option of the Clip Reality Mesh tool. |
mrmesh unclip |
Opens the Unclip Reality Mesh tool. |
mrmesh unclip all |
Selects the All mode in the Unclip Reality Mesh tool. |
mrmesh unclip element |
Selects the Identify mode in the Unclip Reality Mesh tool. |
mrmesh unclip fence |
Selects the Fence mode in the Unclip Reality Mesh tool. |
scalablemesh geocoordinatesystem details |
Opens the Geographic Coordinate System Properties dialog. Use this dialog to visualize the GeoCS properties or modify the Vertical Datum of the selected Scalable Mesh attachment. |
scalablemesh geocoordinatesystem select |
Opens the Select Geographic Coordinate System dialog. Use this dialog to browse browse the GeoCS library and select a new one for the selected Scalable Mesh attachment. |
scalablemesh geocoordinatesystem delete |
Deletes the GeoCS of the selected Scalable Mesh attachment. |
Key-in |
Description |
scalablemesh new |
Starts the New Terrain Scalable Mesh tool. |
scalablemesh status |
Use to verify if any changes were made to the source files of the selected Scalable Mesh attachment. |
scalablemesh modify |
Starts the Modify Terrain Scalable Mesh tool. |
scalablemesh generate |
Use to generate new or update existing Terrain Scalable Mesh. |
scalablemesh groundextraction |
Starts the Ground Extraction tool. |
scalablemesh extractelevationpoints |
Starts the Extract Elevation Points tool. |
scalablemesh quickgroundextract |
Starts the Quick Ground Extraction tool. |
scalablemesh quickgroundextract block |
Selects the block method in the Quick Ground Extraction tool. |
scalablemesh quickgroundextract shape |
Selects the shape method in the Quick Ground Extraction tool. |
scalablemesh quickgroundextract element |
Selects the element method in the Quick Ground Extraction tool. |
scalablemesh volumecalculation |
Starts the Volume Calculation tool. |
scalablemesh volumecalculation block |
Selects the block method in the Volume Calculation tool. |
scalablemesh volumecalculation shape |
Selects the shape method in the Volume Calculation tool. |
scalablemesh volumecalculation element |
Selects the element method in the Volume Calculation tool. |
scalablemesh tileterrain |
Starts the Tile Terrain tool. |
scalablemesh convert |
Starts the Convert 3MX to Scalable Mesh tool. |
scalablemesh saveas |
Starts the Save As Scalable Mesh tool. |
scalablemesh upload |
Starts the Upload to ProjectWise ContextShare tool. |
scalablemesh uploadwithclips |
Starts the Upload with Clips tools. Use the bake clips in Scalable Mesh before uploading to ProjectWise ContextShare. |
