| Product(s): | Hevacomp Mechanical Designer | ||
| Version(s): | V8i (N/A) | ||
| Area: | N/A | ||
| Subarea: | N/A |
For Shell and Core developments an SBEM error will occur if Stage of Analysis is set to As built, and then the Room is a shell area and building services systems have been assumed option is selected:
In Hevacomp V25, the above settings will result in a generic SBEM error message when calculating results:
In Hevacomp V26, a new error message has been added to assist in diagnosing this issue:
At the As Built stage of development building services are expect to be fully defined. You will need to deselect Room is a shell area and building services systems have been assumed option to allow the calculation to proceed..
