Change owner of a Reality Data
1) Obtain permission to manage reality data that are associated to a ProjectWise Project.
2) List Reality Data that are associated to the ProjectWise Project.
3) In the list, locate the Reality Data you want to rename and select it by toggling ON the checkbox.
4) Click the information button:
5) In the side panel, click the Edit button:
6) Type the email address of the new owner in the "Owner" field.
7) Click the save button:
Note: The above steps can also be performed by users who possess the “Administrator” or “Co-Administorator” user roles.
