Monitor Usage
1) Go to https://connect.bentley.com/
2) Scroll down to the My Services and click the ProjectWise ContextShare tile:
3) Click the Settings button.
4) Click Usage Reports:
Note: The usage report will open in a new tab.
5) Use the Start date and End date controls to filter data in the dashboar according to your billing period:
6) In the Report Type list select Dashboard:
7) In the Report Type list select Processing Unit:
8) In the Report Type list select Management Unit:
Note: You can click the Export button in the Processing Unit and Management Units views to export the content of the report to a .csv file.
