| Product(s): | Hevacomp Legacy |
| Version(s): | V8i |
| Area: | Troubleshooting |
Disambiguation If you receive a run time error 429 with this associate screen corruption then please see this document instead. |
During the installation a lack of permissions have stopped components being registered correctly.
You should not normally need to reinstall the software
Please navigate into the installation folder:
C:\Program Files (x86)\Bentley\Hevacomp V8i\Hevacomp\
In this folder, locate these five programs:
| Hevbanner.exe | HevenergyPlus.exe | DDB.exe | Netsys.exe | Nimbus.exe |
For each program in turn, right click on them and select Run as administrator from the context menu. If required, provide an administrator password.
If you receive an onscreen message after running one of the programs, ignore the message. If the program opens, close it using normal methods.
Once all of the programs have been run in this manner you should be able to run your software correctly from the Bentley Hevacomp V8i icon, or from the Start menu link.
