| Product(s): | Hevacomp Mechanical and Electrical Designer | ||
| Version(s): | V8i (26.xx.xx.xx) | ||
| Area: | N/A | ||
| Subarea: | N/A |
Disambiguation If you receive a run time error 429 without this associate screen corruption then please see this document instead. |
Following a new installation, attempting to run Hevacomp produces either of the following errors:
This is usually due to a lack of permissions during the installation process, which blocks registration of the RSS feed components.
You should not need to re-install the software to resolve this issue
Update your software to the latest version.
