View Layout Selection and Synchronization
1) Open a Reality Data in the Reality Data Web Viewer.
2) Use the "View Selection" tool in the application’s lower-right corner to select a view layout for the Reality Data Web Viewer.
* Note that these view layouts can be combined with the Orbit Photo Navigation.
3) When a "multiple view" view layouts is selected (e.g. Split or Swipe views), tabs are added to the top of the Reality Data Widget to let you manage Reality Data display for each viewport.
4) To synchronize viewports in the "Split Vertical" or "Split Horizontal" layouts, simply click the "Sync Views" tool located under the "View Selection" tool.
