| Product(s): | Electrical Design - Connect | ||
| Version(s): | V8i (N/A) | ||
| Area: | N/A | ||
| Subarea: | N/A |
When attempting to place annotation on a Connect schematic, a Run Time Error 6 occurs. This will force the program to exit and any changes since the last project save will be lost.
This error is due to extreme figures in the co-ordinate offset for the schematic. You should use the various Move functions to reduce the offset significantly.
