1) Open a MicroStation-based product.
2) Select a workset that is assigned to a ProjectWise Project
Note: The assigned ProjectWise Project needs to be one where you have been granted ProjectWise ContextShare's "Use" permission.
3) Open a DGN file.
4) Open the "Point Clouds" dialog and click "Attach Point Cloud From ContextShare".
5) The ProjectWise ContextShare dialog lists all the Reality Data of type "Web Ready Point Cloud" that are associated to the ProjectWise Project. Select one and click "OK" to attach it to the "Point Clouds" dialog.
Related:
