Reality Data Widget Filters
The Reality Data Widget is your gateway to list, manage visibility and control display settings of all the Reality Data that are associated to the current iTwin, and optimized for use in Powered by iTwin web applications. In this page, you will learn about the available options to filter the Reality Data list.
The Search Tool
Use the Search icon to filter the list of Reality Data using a text criteria.
The Filter Tool
Use the “Filter” icon to filter the list of Reality Data using advanced property-based filters.
Apply Filters
Filter By Location
Filter By Time
Filter By Type
