ContextCapture Cloud Processing Console Changelog
Update 11
Version : 10.19.0.1817
New features & Enhancement
Update 10
Version : 10.19.0.786
Update 9
- Now target the new version of ContextCapture Cloud Processing service (old Console projects are not compatible).
- New standard Cesium 3D tiles output
- Export Orbit run
- ProjectWise project association displayed in the project list view
- Filtering option added in the project list view
- New option to draw custom polygons to define the Region of Interest
- New polygon tool to draw surface constraints in the 3D view
- New low level setting available to run the alternate AT engine
- Minor improvements and bug fixes
Update 8
- Lock on photo
- Photo navigation
- Calibration quality metrics
- Tie point selection/deletion tool
- Photo panel
- SRSData directory can be set as template
- Fixed upload issue with weak network connection
- Access to Share Idea form
- New format: OpenCities Planner LodTree
Update 7
- UI compliant with new pricing policy
- CCOrientations published with job processing
Update 6
- New Download manager
- New output formats ESRI, OBJ DGN
- New output formats option: point cloud sampling
- New aerotriangulation option keypoint density, block type
- Scan import now supports scans with unknown source position (auto detection of source position), and POD format.
- New types of tags supported for target autodetection: Chili Tags and April Tags.
- Support of unicode path for input photos.
- Updated coordinate system database (HS2 NTv2, OSTN15, etc.).
- Survey points report: horizontal errors now detailed for X and Y.
- Enhanced Submit dialog
- New display settings (splats size, point cloud size)
- New quality metrics in block 3D view (camera and survey points colorization according to error, distance to input position).
Update 5
- New reconstruction constraint tool
- New hybrid registration mode photo/point cloud
- Complex polygon support for ROI, with mesh clipping
- New export block command
- Camera database autoupdate
- Support of local coordinate system with known unit (for the entire production workflow from scale constraint, control points, etc.)
- Added support for mobile scan format NavVis PLY
- Splats: new textured 3D representation of tiepoints; available after calibration.
- Support of a project SRSData directory that makes the definition of coordinate system extensions easier
- Support of compressed block exchange format XMLZ
- New merge block function (optional when importing block)
- Improved processing error feedback
- Improved job tracking/network communication robustness
Update 4
- Improved upload/download robustness and performance
- New licensing system based on Bentley CONNECT licensing
- Upgraded internal component Bentley Powerplatform
- Survey user interface: New export functions, bug fixes and performance improvement
- Thumbnail loading performance improvement in all views
- Added user tie points in 3D view
- Measurements: fixed issues on scenes using foot unit
- Various bug fixes and user interface improvements
Update 3
- Survey: new quality control tools (statistics display)
- Survey: various UX improvement (zoom view, labels, thumbnails tags, etc.)
- Survey: new import wizard + Propeller format support
- Advanced calibration setting: low level preset loading
- QR code detection (optional) + QR code creation tool
Update 2
- CONNECT Advisor
- Tie point display
- Ability to process only calibration
- Survey point multiselection, and new properties (accuracy, category)
- Photo multiselection (shift /ctrl keys, rectangle, by tie point)
- Region-of-interest
- New output format option Coordinate system
- Measurement in US Survey feet
- Faster download
Update 1
- Support Laser Scans as input data
- New Survey user interface
- New processing option: Speed Factor
