The Reality Data Widget is your gateway to list, manage visibility and control display settings of all the Reality Data that are associated to the current iTwin, and optimized for use in Powered by iTwin web applications. In this page, you will learn how to use display settings to enhance the display of point clouds.
To access point cloud display settings:
Tip: The following icon means that the listed reality data is a point cloud:
| Setting Name | Description | Default Value |
| Locatable |
Controls whether the point cloud can be located by tools (e.g. snapping on point cloud with measurement tools)
| On |
| Transparency |
Sets the degree of transparency to be applied to the point cloud (scale of 0 to 100)
| 0 |
| Color Override |
Controls the display color of the point cloud
| Off |
| Color Picker | Select a color for Color Override | Yellow |
| Color Ratio |
Apply blending ratio between the selected color and the point cloud's per-point RGB value (scale of 0 to 1)
| 0.5 |
| Point Shape |
Select a shape to use in the rendering of the point cloud points
| Round |
| Point Size Factor |
Apply a size factor to the points geometry, (scale of 0 to 100). It is particularly useful to improve display quality when gaps are visible between points.
| 1 |
| Eye-Dome Lighting |
Apply an image-based shading technique that improves depth perception. It is particularly useful for visualizing monochrome point clouds, but can also be useful for point clouds with color information.
| Off |
