The Reality Data Widget is your gateway to list, manage visibility and control display settings of all the Reality Data that are associated to the current iTwin, and optimized for use in Powered by iTwin web applications. In this page, you will learn how to use display settings to enhance the display of reality meshes.
To access reality mesh display settings:
Tip: The following icon means that the listed reality data is a reality mesh:
| Setting Name | Description | Default Value |
| Locatable |
Controls whether the reality mesh can be located by tools (e.g. snapping on point cloud with measurement tools)
| On |
| Transparency |
Sets the degree of transparency to be applied to the reality mesh (scale of 0 to 100)
| 0 |
| Mask by iModels |
Masks the Reality Mesh with the extent of elements in the current iModel. This is particularly useful when the reality mesh intersects iModel elements.
| Off |
| Override Mask Transparency |
Override the mask transparency value globally
| Off |
| Mask Transparency |
Manually set the degree of transparency to be applied to areas of the reality mesh that are masked (scale of 0 to 100)
| 0 |
| Color Override |
Controls the display color of the reality mesh
| Off |
| Color Picker | Select a color for Color Override | Yellow |
| Color Ratio |
Apply blending ratio between the selected color and the reality mesh's texture (scale of 0 to 1)
| 0.5 |
