Product(s): |
MicroStation |
Version(s): |
08.11.09.829 |
Environment: |
N\A |
Area: |
Raster |
Subarea: |
N\A |
How do I attach a map layer that is on a WMS Server?
The code goes thru the layer wininet, the same as Internet Explorer.
In Raster Manager, you would do
File > New > WMS.
You would enter the URL and then select the map layers you want to add
Do a Save or Save and Attach.
This will create a .XWMS which contains the URL and map layer information. When you attach the .XWMS file in Raster Manager you would do
File > Attach > WMS
The raster image will reside on your WMS server and will be displayed in Raster Manager. When you do zooms and pans raster manager goes out to your WMS server and reads the data and displays it
https://www.youtube.com/watch?v=V3LCAzY5vYk
Original Author: |
Frank McAllister |
