| Version: | CONNECT | ||
| Area: | Interchange | ||
| Subarea: | General |
Elenco dei formati di file
MicroStation CONNECT Edition è in grado di importare/esportare i seguenti formati di file per le versioni elencate:
| Formato | Versioni Importabili | Versioni Esportabili |
| DWG |
14, 2000/2000i/2002, 2004/2005/2006, 2007/2008/2009, 2010/2011/2012, 2013/2014/2015/2016/2017/2018 |
| DXF |
11/12, 14, 2000/2000i/2002, 2004/2005/2006, 2007/2008/2009, 2010/2011/2012, 2013/2014/2015/2016/2017/2018 |
| FBX |
Up to and including 2011 |
| STL | ||
| SKP (SketchUp) | Up to and including 2017 | 2015, 2016 and 2017 |
| JT | ||
| IGES | 2.0, 3.0, 4.0, or 5.0 fixed-length ASCII | 4.0, 5.0, or 5.3 fixed-length ASCII |
| Parasolid XMT | All up to 13.0 | 7.0, 7.1, 8.0, 9.0, 9.1, 10.0, 10.1, 11.0, 11.1, 12.0, 12.1, or 13.0 |
| ACIS SAT | All up to 25.0 | 25.0 |
| CGM | 1.0 | 1.0 |
| STEP AP203 | International Standard (IS) | International Standard (IS) |
| STEP AP214 | Draft International Standard (DIS) | Draft International Standard (DIS) |
| Acute3D (.3mx) |
La tabella seguente elenca i formati di file che possono essere solo esportati o solo importati in MicroStation:
| Solo Export | Solo Import |
| VRML World | TerrainModel LandXML |
| SVG | Image (JPG, BMP, TIF, GIF, and others) |
| OBJ | TXT |
| Luxology (LXO) | IFC |
| Google Earth (KML) | RFA (read Only) |
| Collada (DAE) | |
| U3D |
Vedi Inoltre
Bentley iModel Bridges - File Format Support
Articolo in Lingua Originale
