Authenticating the Bentley SELECTserver Gateway When Integrated Windows Authentication Is in Use
 Product(s):Bentley SELECTServer, Bentley SELECTServer Gateway
 Version(s):08.11.00.00 - Present
 Environment: N/A
 Area: N/A
 Subarea: N/A
 Original Author:Jonathan Jezorski , Bentley Technical Support Group
If your SELECTServer requires the use of Integrated Windows Authentication, the SELECTServer Gateway will not work as the user account for the SELECTServer will not work for the SELECTServer Gateway.  To remedy this problem, create a new user via Local Users and Groups, or if the Server is set as a domain controller, please create a user within Active Directory.  The steps for creating a user via Local Users and Groups are as follows:
1. Open Computer Management.
2. Expand local users and groups
3. Open the Users folder
4. Right click the screen and choose New User
5. create a new user and a strong password.  Uncheck User must change password and next logon and check user cannot change password and password never expires.
6. click create
7. Expand the groups folder under local users and groups
8. Double click the users group and confirm the new user is a member
9. Click ok
10. Expand Services and applications
11. Expand Internet Information Services
12. Expand Websites
13. Expand Default Website
14. Right Click on the BSS directory and choose properties
15. Choose the Directory Security Tab and click the Edit button under Authentication and Access Control
16. Click Integrate Windows Authentication and then click Ok
17. Expand BSS
18. Right click on WS and choose properties
19. Choose the Directory Security Tab and click the Edit button under Authentication and Access Control
20. Click Integrate Windows Authentication and then click Ok
21. Expand BSS
22. Right Click on the WS directory and choose properties
23. Choose the Directory Security Tab and click the Edit button under Authentication and Access Control
24. Change the user name to the new user created in step 5 above.
25. Enter the created password and click ok
26. Confirm Password
27. Choose Start>Run> type in IISRESET > click Ok
28. When the CMD prompt disappears, reopen the administration page.
External Links
Bentley LEARN Server
Comments or Corrections?
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article in the "Comments" area below. THANK YOU!
Other Language Sources
Deutsch
