| Applies To | ConstructSim | ||
| Product(s): | ConstructSim | ||
| Version(s): | 08.11.09.219 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | CSST and CSST-User | ||
| Subarea: | MS Access | ||
| Original Author: | Marc Brana, Bentley Technical Support Group | ||
The user is not able to open CSST and/or CSST-user. The issue is due to a Windows Update that causes Windows Common Controls associated with MSCOMCTRL.OCX file updated in the patch.
For further information regarding this issue follow the link:
http://support.microsoft.com/kb/2748410
Solutions:
Method 2: Re-register MSCOMCTL.OCX from an elevated command
prompt
If you're not familiar with the steps to open an elevated
command prompt, you can find the steps here(http://windows.microsoft.com/en-US/windows-vista/Command-Prompt-frequently-asked-questions).
Windows XP users can open a command prompt normally.
Regsvr32 /u "C:\Windows\SysWOW64\MSCOMCTL.OCX"
Regsvr32 "C:\Windows\SysWOW64\MSCOMCTL.OCX"
Regsvr32 /u "C:\Windows\System32\MSCOMCTL.OCX"
Regsvr32 "C:\Windows\System32\MSCOMCTL.OCX"
Method 4: Execute a batch file to update your system
automatically
NOTE: Backing up the registry is recommended prior to executing these steps.
reg delete
hkcr\typelib\{831FDD16-0C5C-11D2-A9FC-0000F8754DA1}\2.0 /f
if exist %systemroot%\SysWOW64\cscript.exe goto 64
%systemroot%\system32\regsvr32 /u mscomctl.ocx
%systemroot%\system32\regsvr32 mscomctl.ocx
exit
:64
%systemroot%\sysWOW64\regsvr32 /u mscomctl.ocx
%systemroot%\sysWOW64\regsvr32 mscomctl.ocx
Exit
NOTE:
You can remove the reg delete line from the batch file if you have found that you don't need to remove the registry key listed above to get your application to work.
Environment:
Windows 7, ConstructSim SS4 08.11.09.219
Avoidance:
None
[[SELECTsupport TechNotes and FAQs]]
