UD Groups - Closing User Defined group would crash ConstructSim - [TN]
Document Information
Document Type: TechNote
Product(s): ConstructSim V8i
Version(s):
Original Author: Marc Brana, Bentley Technical Support Group
A crash will occur when the user will close any/all User Defined (UD) group(s). The crash will happen at a
random time after closing a UD group.
Workaround:
Dock all UD Groups on the side panels of ConstructSim. This should be done the first time the VPM is opened.
When a new VPM is created or posted by the Admin, the user may have to re-dock the UD Group(s) again.
A TR has been filed in Flawtrack TR 292671
[[SELECTsupport TechNotes and FAQs]]
External Links
Bentley LEARN Server
Comments or Corrections?
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to the "Comments" area below. THANK YOU!
