Product: |
OpenRoad SignCAD 2023 |
Version: |
23.00.00.151 |
Area: |
Troubleshooting |
Original Author: |
Bentley Global Technical Support |
Problem:
Sign text is not visible or displays very small when referenced into sheet model in OpenRoads Designer or MicroStation using the SignCAD to DGN application.
1) Pick Home>Primary>Attach Tools>References.
2) In the References dialog, select the reference file with the signs and TURN OFF the Use Active Annotation Scale setting.
