Product: RAM Structural System
First Affected Version: 2024
Fixed in Version: 24.00.02
Area: Steel Column design
Issue #: 1509441
Using View/Update or the Column Design Report on a steel gravity column with net tension (typically due to the back-span uplift of a cantilever beam) causes a crash in the RAM Steel Column module.
Add a small amount of load to prevent the tension or check the column as a lateral column in RAM Frame - Steel Standard Provisions mode.
To be fixed for version 24.00.02.
