ADINA 2023 Update 1 Release Notes
Release Date: January 2024
Version: ADINA 2023 Update 1
Version Number: 23.00.01.16
Product Version Naming Convention
Product versioning for Bentley Systems is now based on the calendar year of the major release according to software industry practice. This is the first ADINA Minor release following the 2023 version, thus version 23.00.01.16.
Download and Installation Instructions
Installation files for current and past RAM Concept releases can be downloaded from the Bentley Software Downloads page. After signing-in, the ADINA installers can be located by searching for ADINA.
Changes in Licensing
There have been no changes in licensing since the last version. ADINA is still licensed in 3 tiers, ADINA, ADINA Advanced and ADINA Ultimate with an optional ADINA Parasolid Modeler interface that works with any tier.
The Bentley licensing component for Linux was updated in this release to support the use of a checked-out license to a Linux machine with a period "." in the host name.
Security Risk Advisory
Bentley is committed to continuously investigating and rectifying security vulnerabilities affecting its products and services. Regular checks and security fixes are a part of our releases to ensure better resilience. In this version updates were made to the Bentley Connection Client and License Client.
Table of Supported Platforms
Platform  Operating system  Fortran compiler  Intel MKL library
Windows  Windows 8, 8.1, 10, 11  Intel Fortran Compiler Classic, version 2022.1.0  MKL 2022.1.0
Linux  Linux kernel 5.4 and higher, glibc 2.31 and higher
  1. All program versions are 64-bit, using the x86_64 architecture.  The Intel 64 and AMD64 implementations of the x86-64 architecture are supported.
  2. The CPU must support the AVX extensions to the x86_64 instruction set architecture.  Most Intel and AMD CPUs released after 2011 contain these extensions.
  3. The following Linux distros comply with the minimum operating system requirements for
Linux:
The Linux computer must have Firefox and libssl.so.1.1 installed, otherwise the Linux installation will abort. Firefox and libssl.so.1.1 are used for Linux licensing. Instructions for installing Firefox and libssl.so.1.1 are distro-dependent. libssl.so.1.1 is a system library used with OpenSSL 1.1.1.
Corrections and Enhancements
AUI
1299001: AUI-Plot could not load porthole file when RESULTS=OP2+PORT was specified in the MASTER command due to duplicated results. The error was "Error reading ADINA porthole file."
1288286: A Core dump error could occur in AUI when using Parasolid Modeler to define Sewn Bodies. This only occurred with a specific series of steps selecting bodies from table after receiving a message about Missing Geometry.
1269938: In AUI Post-Processing, the Reaction plot of distributed contact traction should have a maximum value in red. Instead, it was sometimes orange. Furthermore, the shape of the distributed contact traction should be trapezoidal in shape for non-uniform traction. When using Fast Graphics this would display in flat steps. This could also affect plotted non-uniform beam loads, but only in Fast Graphics mode.
1213074: With some graphics adapters, the background color would not immediately change based on user input.
1327616: In AUI the solution time indicated for a MESHPLOT may have the wrong solution time. This happened when the current time step size was large, but the current solution time required many significant digits to display properly.
Structures
1321596: In ADINA Structures, when initial velocity was defined in the model, the initial kinetic energy result was not correct, it was double the correct value.
CFD
1304952: For large CFD and/or FSI problems, stack overflow may have occurred. This situation cannot be predicted, since it depends on the specific problem and the system. When encountered, the process stops without solution, but did not affect the solution quality otherwise.
Femap Transor
1308917: For a Femap model with 2D contact surfaces, Transor for Femap will translate it into a Nastran file with BEDGE commands, and AUI will create the corresponding element edge sets when importing the Nastran file. However, if the Femap model also had thermal loadings (heat flux, convection, radiation, and heat generation) or FSI boundaries applied to the edges of 2D solid elements, additional element edge set IDs may overlap with those from the 2D contact surfaces causing edge loads to be applied incorrectly.
Available Documentation
No changes were made to the other ADINA documentation for this version except that the pdf files now allow information to be copied to the clipboard.
