CONNECT Upgrade to Infrastructure Cloud
Introduction
As part of our ongoing efforts to create the best user experience across the entire lifecycle through Bentley Infrastructure Cloud, we are consolidating our portals into only one – Bentley Infrastructure Cloud.
By accessing all your projects and data from a single location, you will gain new capabilities and more integrated and collaborative workflows across design, build and operate phases, resulting in more successful project delivery outcomes.
This is why we allow Project Owners and CONNECT Administrator to Upgrade CONNECT projects to Infrastructure Cloud Projects.
Before you start upgrading your CONNECT projects
There are several things you need to know before you start the upgrade process:
Entitlements / Licenses
CONNECT projects do not check for entitlements. When users access a CONNECT project they will record a Bentley Infrastructure Cloud Connect usage when using the different services, as Share, ProjectWise Web Connections, Deliverables Management, Project Insights, Issues, Forms or Component Center.
Infrastructure Cloud Projects take advantage of Bentley Infrastructure Cloud Connect and Bentley Infrastructure ProjectWise entitlements, which not only will give the users access to Infrastructure Cloud Projects, but also define the maximum set of permissions.
Important
Bentley’s policy is to set the Default Access configured at the Entitlement/Licenses Management service for every application as Allowed, meaning all users in an Organization are allowed to use any Entitlement/License.
If Everyone is granted access to Bentley Infrastructure Cloud Connect and Bentley Infrastructure Clooud ProjectWise, all users who access a Bentley Infrastructure Cloud project in their organization (or an external project that is setup with Bring Your Own License), will consume a Bentley Infrastructure Cloud ProjectWise entitlement disregarding the role assigned at the project level
To know more about Entitlements – please read this article.
As Best Practice, you should always check if Bentley Infrastructure Cloud Connect and Bentley Infrastructure Cloud ProjectWise entitlements have been Allowed/Denied for users in your organization to prevent incuring excess costs.
To know how to configure Entitlements – please read this article.
Entitlements / Permissions
In CONNECT, Permissions/Restrictions must be set by Roles.
In Infrastructure Cloud, Bentley Infrastructure Cloud Connect and Bentley Infrastructure Cloud ProjectWise entitlements will define the maximum set of permissions users will have when they access the project. Permissions can be restricted further using Roles, but you cannot grant permissions higher than the entitlement allows.
Who can Upgrade CONNECT projects?
Account Admins, CONNECT Service Administrators or Project Owners can upgrade CONNECT projects to Infrastructure Cloud Projects using the single project upgrade.
Account Admins and CONNECT Service Administrators can use the Bulk project upgrade to upgrade up to 1000 CONNECT projects at once
How to upgrade CONNECT projects to Infrastructure Cloud Projects
There are two options to upgrade CONNECT projects to Infrastructure Cloud Projects. One single project at a time or serveral projects at the same time.
Note: Once you upgrade a CONNECT project to an Infrastructure Cloud Project, you will no longer be able to open the project through CONNECT.
Important
Single project Upgrade
To upgrade a CONNECT project to an Infrastructure Cloud Project
Note: The first time you click on a CONNECT project, you will get a pop-up to remind you to read about pre-requisites
Click Here for details – will take you the article
Yes, I read it – will dismiss the pop-up ad let you continue.
Click on the browser’s back arrow – to go back to the Landing Page
(This is a one time pop-up)
Several projects at the same time
To Upgrade several CONNECT projects to Infrastructure Cloud Projects, at the same time
CONNECT Upgrade – Frequently Asked Questions
Is CONNECT being deprecated?
As part of our ongoing efforts to create the best user experience across the entire lifecycle through Bentley Infrastructure Cloud, we are consolidating our portals into only one – Bentley Infrastructure Cloud. Eventually, there will be no more projects created in connect.bentley.com, but existing projects will be accessible at the new URL, and we will continue to allow users to upgrade to newer functionality at the pace they desire.
Will user’s current CONNECT login credentials work on Infrastructure Cloud Portal?
Yes. User’s current CONNECT login credentials will provide them with access to their projects on Bentley Infrastructure Cloud, although their level of access will be determined by their entitlement – Bentley Infrastructure Cloud Connect or Bentley Infrastructure Cloud ProjectWise.
What features from my CONNECT project will be available in Infrastructure Cloud project?
All CONNECT projects can be upgraded. The features are Share, ProjectWise Web Connections, Project Insights, Issues, Forms, Component Center, iModels and Reality Data.
Only Portfolio Insights is not supported in Bentley Infrastructure Cloud
What does it mean that a project cannot be re-provisioned?
In Bentley Infrastructure Cloud projects, you can use a project as template and copy the template settings by re-provisioning the project applying the template one. By re-provisioning you can copy forms definitions and permissions, document folders and files, enable Deliverables Management (if it was not originally enabled) and Deliverables Management settings, etc
If a CONNECT project with files in Share was upgraded to Bentley Infrastructure Cloud, this project will not be able to be re-provisioned. So, before upgrading consider if you will want to use Deliverables Management in the future, so you can turn it on before upgrading to Infrastructure Cloud
Will any of my data or connections be lost or interrupted because of the upgrade?
No interruption of service or connections will occur because of the upgrade and no data will be lost.
Will the datacenter location be changing due to this upgrade?
A. No. No data will be moved or copied
Can I choose if I want to Provide License to external team members or not?
In Bentley Infrastructure Cloud Projects, Project Owners may choose if they want to Provide License to external team members. Please refer to this article for more information
After upgrading a CONNECT project to Infrastructure Cloud Project,  it is always a Best Practice to check Provide License for external team members. Just go to Administration – Provide License for External Participants
Will this upgrade affect my existing Work Area Connections to ProjectWise?
No. Work Area Connections and ProjectWise Drive settings will be the same. Users will be able to continue working as they were in CONNECT.
What will happen with my existing links to Documents, Deliverables Management, Forms, etc
All your existing links will still work without any intervention. You may notice the link redirecting to infrastructurecloud.bentley.com.
What will happen with my Office 365 co-authoring settings?
Office 365 co-authoring settings will remain the same. No need to re-configure the settings.
Where do I find Enterprise Services to modify PW Drive, Co-authoring, Document Wizard and Component Center?
Enterprise Services can be found at the top right corner of the header. Please refer to this article for more information on Enterprise Services.
How will this upgrade affect the External Organizations and their projects (used to Collaborate with Deliverables Management)?
Upgrading your CONNECT projects to Bentley Infrastructure Cloud projects will not affect your External Organizations and their projects used to Collaborate with Deliverables Management. External Organizations do not need to upgrade their CONNECT projects to Bentley Infrastructure Cloud.
Will I be able to pay for External Organizations invited to Collaborate with Deliverables Management usage? How will I manage their Entitlements?
Project Owners may select which External Organizations invited to Collaborate through Deliverables Management they want to cover the costs for. All participants in the covered External Organizations will consume a Bentley Infrastructure Cloud Connect entitlement and have the corresponding permissions. Please refer to this article for more information
After upgrading a CONNECT project to Infrastructure Cloud Project,  it is always a Best Practice to check Manage External Organizations - Billing Settings, to verify that you are Covering the Costs of selected organizations.
What will happen with my iModels and their connections? Will they still work?
Current iModel connections will still work. These connections are the same as in CONNECT. These iModels will have a PREVIOUS-GEN tag. You will be able to resynchronize existing connections and create new connections, using the CONNECT synchronization service which will remain available.
Empty iModels or New iModels will be able to use Bentle Infrastructure Cloud connections and will benefit from its new features. Please refer to this article for more information.
Existing CONNECT iModels can be used to Create Composite iModels along with new iModels.
What happened to Teams integration with my CONNECT project? Will this integration still work with Infrastructure Cloud Projects?
There is no integration between Teams and Bentley Infrastructure Cloud Projects. Teams app Website can be used to add an Infrastructure Cloud Project URL to a Team’s group or Channel
