Export to PLT
Product:
OpenRoad SignCAD 2024
Version:
24.00.00.56
Area:
How-to
Original Author:
The instructions and video below show how-to Export to PLT from OpenRoads SignCAD 2024 and bring the PLT file into other print/cut control software for manufacturing.
Step 1:  Select the file, sign or other element (arrow, graphic, etc.) to export.
Step 2:  Pick the File tab to go to the Backstage and pick Export. Select the Export to PLT or Export Selected to PLT option.
Step 3:  In the Export Plot dialog, press the button with the three dots to the right of the Plt File Name, enter a File name and press Save.
Step 4: Set the desired Export Plot parameters and press Export to generate the PLT file.
Step 5: Bring the saved PLT file into your cutter/plotter software to cut the sign.
