Special Concrete Shear Wall in-plane shear capacity error
Product: RAM Structural System
First Affected Version: 24.00.00
Fixed in Version: 24.00.02 (expected)
Issue #: 1541402
Problem Description
In RAM Concrete Shear Wall design, for Special Concrete Shear Walls, the in-plane shear capacity, Vn, based on ACI 318-19 Eq 18.10.4.1 was too low. and overly conservative. There error was due to a units problem with f'c. The problem also affects ACI-318-14.
There was no problem using Ordinary shear walls, and there was no error when the upper bound limit on Vn controls (i.e. 8 * root (f'c) * Area from Eq. 18.10.4.4)
Work Around
None
To be fixed for version 24.00.02
