Custom Applications
See the below list for videos on Ohio DOT's custom applications.
*Videos to come
Projects
Create Workset
OHDOTCEv02 Project Indexer
WorkSet Importer
Files
OHDOT Create Design Files
Tag Sets to Item Types
OHDOT Sheet Cells
OHDOT Sheet Manager
Item Types Disappearing (FIX)
OHDOT Cross Refs
OHDOT SCD List
OHDOT Title Sheet Map - DGN Version
OHDOT Plan Signatures
Plan Preparation
OHDOT Add
OHDOT Balloon
OHDOT Get View Rotation
OHDOT Pavement Marking
OHDOT Plan Notes
OHDOT Property Line Marker
OHDOT Signs
OHDOT DU Item Type Sync
Geotechnical
OHDOT Geometry Points
OHDOT Geotechnical Report
OHDOT gINT Conversion
OHDOT gINT Summary Converter
Structures
OHDOT Rebar Chart
Survey
OHDOT
Existing Pipes
OHDOT
Rotate Survey Symbols
