An Employment Agreement is an attribute that is added to the employment section of a Person record. Employment Agreement information can be used by a company’s payroll to support wage criteria.
Employment Agreements - Add/Edit/Delete
- Click on Settings > Administration > Employment Agreements.
- To create an Employment Agreement, click on Add Employment Agreement.
- Enter the Employment Agreement Name.
- Click Create Employment Agreement.
- To edit an Employment Agreement, click
, make the required change and click Update Employment Agreement. - To delete an Employment Agreement, click
If an Employment Agreement has a grey icon
, there is existing associated data with a Person Resource and cannot be deleted.
Employment Areas - Add/Edit/Delete
An Employment Area is an attribute that is added to the employment section of a Person record. Employment Area information can be used by a company’s payroll to support wage criteria.
- Click on Settings > Administration > Employment Area.
- To create an Employment Agreement, click on Add Employment Area.
- Click Create Employment Area.
- To edit an Employment Area, click
, make the required change and click Update Employment Area. - To delete an Employment Area, click
If an Employment Area has a grey icon
