| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | Dec. 2016 10.01.00.09 |
What are the local axis directions when +Z-axis is vertically up in AutoPIPE?
Local Axis directions when Y-axis is vertically up:
Local Axis directions when General Model Options, Vertical axis direction = Z-axis will be identical to above orientation. Again local axis is not dependent on General Model options "Vertical Axis direction" setting. This is by design.
See AutoPIPE help:
