Q. Available features in AutoPIPE Vessel 42.04 - 42.01 based on license type selected
Product(s): AutoPIPE Vessel
Version(s): ALL
Area: License
Date Logged
& Current Version
March 2022
42.04
Problem:
What features / licensing choices are available in AutoPIPE Vessel 42.04?
Starting with AutoPIPE Vessel 41.05.00.009 and higher there are 3 types of licenses available:
1. Heat Exchanger
2. Standard
3. Ultimate
The following table lists all features and their availability in each of the AutoPIPE Vessel licenses.
Give attention to item super script notation where indicated, details at the bottom.
AutoPIPE
Vessel
Heat Exchanger
AutoPIPE
Vessel
Standard
AutoPIPE
Vessel;
Ultimate
ASME VIII (US design code) 3
PD5500 (British design code) 3
CODAP (French design code) 3
AD-Merlbätter (German design code) 3
EN 13445 (European design code) 3
GOST (Russian design code) 3
GB (Chinese design code) 3
Pressure Vessel Design & Analysis
Shell and Tube Heat Exchanger Design & Analysis
Storage Tank (API 650) Design & Analysis
Air Cooler (API 661) Design & Analysis
Boiler (NFE) Design & Analysis
Chimney Design & Analysis
SolidWorks – 3D ONLY (sldprt, sldasm file creation) 1
Export/Import to PDS
IFC File Export
Microstation - 2D, 3D (dgn file creation) 1
AutoCAD - 2D, 3D (dwg file creation) 1
Local Load 2
Expansion Joint and Bellows Design (including TEMA 9th FEA method) 2
Tubesheet layout (no tubesheet calculations, only layout design) 2
Anchor Base 2
Shell / Head / Cone / Flange 2
Beam design 2
U Bend 2
Flat plate with stay bolts 2
Cost Estimate
Fatigue Analysis
Motion Analysis
Blast Analysis
Wind, Vortex shedding, Seismic Calculations
Support and Lifting Accessories Calculations
Compress file import (build 7510)
AutoPIPE Nozzle Load Import
Import of Aspentech and HTRI files
PXF file import export
Platform, ladders modeling, external loads
External loads, structural and piping clips, packing, trays, coil, stiffeners
(1)
a) AutoPIPE Vessel uses a CAD plugin to create drawings, therefore a cad program (ex. AutoCAD, Microstation, Solidworks, etc..) must have been installed before trying to export the respective drawing from AutoPIPE Vessel.
b) CAD export capability will be limited only to the type of equipment that can be modeled while using a Standard or Heat Exchanger or Ultimate license version of the program.
Example:
With Vessel Standard license enabled, user cannot export a Shell & Tube heat exchanger model to drawings. User must have a Vessel Ultimate or Heat Exchanger license enabled to export a Shell & Tube heat exchanger model to drawings. Because, Shell & Tube heat exchanger can only be modeled with an Ultimate or Heat Exchanger license and not a Standard license.
(2) Individual component modeling / calculations can be performed instead of full equipment modeling and design.
(3) Choice of one code (per user’s choice and as mentioned in license agreement) is included in the license for Vessel Standard or Heat Exchanger. However, the user may select more than one code in which case they will be charged separately for the code that is NOT covered in the license. Conversely, Ultimate license includes ALL the design codes.
Release Notes
License Configuration - What do you see
Subscription Entitlement Service
AutoPIPE Vessel
