RAM Frame - Shear Wall Analysis Module Tutorial
Whether your shear walls have opening in them or not, the RAM Frame – Shear Wall Analysis module can be used to get more precise information about the force in the lateral walls.
To start the Shear Wall Analysis Module:
The program launches a separate application in the 3D view akin to the Steel Column module. Most of the actions in this mode are done from an elevation view of a shear wall.
NOTE: I f you start this program from an elevation view in the RAM Frame analysis mode, the same elevation will automatically come up.
Section Cuts
The Shear Wall Module works by reporting the forces on user-specified section cuts through walls. The section forces can be obtained graphically or through reports. When the program is launched from the RAM Frame Analysis Mode – Load Cases, then the results are for individual load cases. When the program is launched from the Load Combinations mode, then the section results are all given for the combinations.
The cursor will change into a cross-hair type cursor at this point.
Final Section Cuts
When you let go of the cursor, an options box will pop up.
The Green section cut will be adjusted to be exactly 12” from the lowest left corner of the wall where the section cut started.
NOTE: S ection cuts can be altered after created using the command Assign – Section Cuts – Change. To review a table of the section cuts all at once, select Assign – Section Cuts – List.
Once complete, the three completed cuts should look like the following figure.
Completed Section Cuts
To see the shear forces on the various section cuts:
To see a table of the forces on an individual section:
A table of the section forces will appear. The forces are separated into axial forces P (positive = compression), overturning moment (Mmajor), out-of-plane moment (Mminor), shear along the length of the cut (Vmajor), shear perpendicular to the wall (Vminor) and torsion. For a wall with no included lateral columns, the minor axis shear and moment values (as well as torsion) will be zero since the walls are not assumed to have any significant out-of-plane stiffness in the analysis.
Reports
The reports menu has printable versions of the section cut information. For a printable version of the section cut forces:
Another useful report is the Envelope report. This report includes the maximum and minimum forces on each section cut similar to the force envelope reports in the analysis mode of RAM Frame. It is more useful to generate this report while working with load combinations. To get such a report:
