| Product(s): | RAM Frame Analysis | ||
| Version(s): | 13.00.00.00 and later | ||
| Area: | Analysis | ||
| Subarea: | |||
| Original Author: | Jeremy Hoesly, Bentley Technical Support Group | ||
The following message appears in a black DOS window when attempting to run an analysis in RAM Frame:
OMP: Warning #72: KMP_Affinity: affinity only supported for Intel processors.
OMP: Warning #71: KMP_Affinity: affinity not supported, using "disabled"
On some computers using version 14.07.01 the symptom is a program crash without any message.
The direct sparse solvers used by RAM Structural System and RAM Elements utilize multiprocessing libraries provided by Intel. The libraries function properly with Intel processors but not with AMD processors.
TR 3581 has been filed with the RAM Structural System development team.
Use one of the direct solvers instead of the direct sparse solvers.
To change the solver used in an existing model:
To change the solver for new models:
[[KMP_Affinity Error During Analysis in RAM Elements]]
