| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | Load generation | ||
| Subarea: | Moving Load generation | ||
How to apply horizontal moving loads
As of now the Moving Load generator in STAAD.Pro can generate loads in vertical direction only. There is no automated facility to add horizontal loads to these generations. This feature would be implemented in a future STAAD.Pro version. For now as a temporary workaround, one can make use of notional loads to have these horizontal loads generated for each position of the moving load.
Here is an example of how this can be done. Let’s say there is a load case 100 which includes structure selfweight. It is followed by a moving load generation case which would generate 11 load combinations from 101 to 111
LOAD 100 LOADTYPE None TITLE SELFWEIGHT
SELFWEIGHT Y -1
LOAD GENERATION 11
TYPE 1 0 0 0 ZINC 1
Subsequently one can manually create additional cases ( using command editor ) where any of these generated load combinations can be combined with the horizontal load as shown below
LOAD 1001 LOADTYPE None TITLE LOAD CASE 1001
REPEAT LOAD
100 1.0 101 1.0
NOTIONAL LOAD
101 X 0.1
NOTIONAL LOAD
101 Z 0.1
The above load case 1001 is created by first combining the first of the generated combinations 101 with the selfweight load case 100. Horizontal loads ( Notional loads ) are then added by multiplying the load combination 101 by a factor of 0.1 and these are applied in X and Z directions simulating a longitudinal thrust and lateral thrust at the moving load location.
An example is attached uploaded below
communities.bentley.com/.../Structure1.std
There are a few factors that one needs to keep in mind though
