| Product: | STAAD.Pro | ||
| First Affected Version: | 20.07.00.01 | ||
| Found in Version: | 20.07.11.50 | ||
| Released in Version: | 20.07.11.70 | ||
| Environment: | All | ||
| Area: | Analysis | ||
| Subarea: | Pdelta analysis | ||
| Issue #: | 371896 |
In a Pdelta analysis with tension/compression, the pdelta effect is not considered in section force calculations unless each load case is followed by the PDELTA ANALYSIS and CHANGE.
Provide PDELTA ANALYSIS and CHANGE command after each load case for which analysis/design is to be carried out
This has been addressed in 20.07.11.70
