ACI 318 Column Shear Capacity
 Product(s):RAM Concrete Column
 First Affected Version:
Found in Version:14.07.01.01
Fixed and Released in Version15.04.00.00
 Environment:N/A
 Area:Design
 Subarea:N/A
 Defect Number:205403
Problem Description
The shear strength provided by shear reinforcement (Vs) was calculated using an incorrect effective depth. The defect resulted in unconservative shear capacities.
Reason
The effective depth was calculated using the column dimensions and clear bar cover only, but not the diameter of the shear or vertical reinforcement. The correct effective depth was used to calculated the shear strength provided by the concrete (Vc).
Problem corrected in version 15.04.00.00.
[[ACI Column Controlling Combination for Shear]]
