Applies To | |||
Product: | RAM Steel | ||
First Affected Version: | |||
Found in Version: | 15.03.00.00 | ||
Fixed and Released in Version: | 15.04.00.00 | ||
Area: | Design | ||
Issue #: | 540806 / 562996 |
The compression flange yielding capacity determined in AISC 360-05 or 10, Section F4 for qualifying sections was incorrectly determined.
Where the governing capacity for sections evaluated under Section F4 "Other I-Shaped Members with Compact or Noncompact Webs Bent about their Major Axis" was the Compression Flange Yielding limit, the reported capacity was incorrectly determined as Fy * Zx rather than Rpc * Fy * Sxc per Equation F4-1.
The issue will be resolved in the release after v15.03.00.
