| Product(s): | MicroStran | ||
| Version(s): | |||
| Area: | Licensing | ||
| Subarea: | |||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
How to open License Configuration and License tool within Microstran.
It is important that to know how to check the settings of the current license configuration that you have set within Microstran.
There are different ways on how you can open the Microstran License Configuration and the License Management tool.
By default when you open Microstran you should see this Dialog Box.
This should show up automatically if you have set the option “Shown on startup”
2. From the Same Dialog Box you can also see the “License Management Tool” tab.
What is the License Management Tool?
Just below the Product Activation Wizard button in the Microstran Licensing Configuration dialog is a button called License Management Tool. This tool allows users to revise and manage licensing settings for all Bentley products. This includes the checking out of a license. Information on this feature is available in the following article:
http://communities.bentley.com/products/licensing/w/licensing__wiki/license-management-tool.aspx
Open Microstran
Go to “Help” menu
About Microstran
Go to C:\Program Files (x86)\Bentley\Engineering\Microstran\Program
Look for MsLicensingUtility.exe double click on the exe file
It will open the Microstran License Configuration tool
