RAM Modeler allows you to model structures for analysis using the rest of the RAM Structural System. It breaks the design down into logical floor types and physical stories, so that when multiple stories are identical, they can all share the same logical floor type. Additionally, it allows for importing of CAD data via DXF files.
The Modeler has comprehensive error checking ("DataCheck") that searches the model for common and uncommon errors in the model that will prevent proper design. This also looks for a number of warning conditions, and presents these as well.
For an overview of all the RAM Structural System modules, refer to [[RAM SS - Modules Overview]]
[[RAM Structural System Support Solutions]]
