| Product(s): | RAM Structural System, RAM Concept | ||
| Version(s): | Various | ||
| Area: | Import/Export | ||
This page is the landing page for user help when integrating RAM Concept models with RAM Structural System. Please use the links below to access the desired help pages. Additional information can be found in the RAM Concept Manual; see Sections "Importing a Database from the RAM Structural System" and "Exporting a Database to the RAM Structural System."
Starting with RAM Structural System version 14.06 and Ram Concept version 5.1, both programs are offered as either 32 or 64 bit applications. In order to integrate the two programs using the methods described in this wiki both must be alike in this regard, so be consistent and install the 32 or 64 bit versions of both applications.
On My SELECT CD or the Software Fulfillment Center, the 64 bit versions are labeled with the x64 suffix. The 32 bit versions have no suffix. The 32 bit versions will work on either a 32 bit or 64 bit machine, but the 64 bit versions require a 64 bit operating system.
Unlinking Ram Concept Files from RAM SS
Ram Concept files lost Converting RAM SS models from 14.05 to 14.06
RAM Concept Lateral Self Equilibrium Analysis
