Applies To | |||
Product(s): | AutoPIPE | ||
Version(s): | CONNECT | ||
Area: | Install | ||
Original Author: | Bentley Technical Support Group | ||
Date Logged & Current Version | Feb 2023 12.08.02.040 |
How Do I Install and license Bentley AutoPIPE 12.08.02.040 and ATS ?.
1. This procedure assumes that Licensing has already been install and configured for the company, If not please contact your Bentley On-Site Admin or Bentley License group to assist you.
2. User currently logged into the computer must have full Administration rights.
3. Suggest that AutoPIPE and ATS are installed by accepting all the default settings.
a. Prefer that the application is not installed over a network connection; suggest that the installation file or DVD be accessed from the user's Desktop or serial port respectively before starting the installation.
b. If you have already installed other AutoPIPE versions, using add/remove programs uninstall:
i. all previous versions of AutoPIPE
ii. " PCF to NTL translator
iii. " ADLPipe to NTL translator
iv. " Bentley STRAIT
Note: Be patient while the application is installing as it is checking to verify programs already installed, verifying drive space, etc.. there may be periods when it appears nothing is happening. Give the system time. In the event the installation stops a warning / error will be presented. Just follow the prompts and be patient. Highly recommended that all applications are closed during the installation process. On average it will take 5-8 min to install everything.
Note: select from the bottom right corner of the video to enlarge to full screen mode.
Finished, AutoPIPE and ATS have now been installed, continue...
If the program will not install based on the instructions above, please log a Bentley Service Request mentioning this page and include a copy of the Error log displayed
Install any Dependencies as needed,
- OpenPLANT Isometric Manager
- ProjectWise
- etc...
Detailed installation procedures for these other applications can be found on other WIKI pages or readme files.
Download, Install, and License AutoPIPE CONNECT 12.00.xx.xx and higher
