Installing Additional Versions of Revit
 Product(s):ISM Revit Plugin
 Version(s):All
 Area: Installation
 Subarea: ISM Menu
ISM commands missing on the Revit menu after installing additional versions of Revit
When you install additional versions of Revit, the ISM commands are not automatically added to the Revit menu.
  1. Go to Control Panel > Uninstall a program
  2. Look for your installed version of the ISM Revit Plugin, right click on it and select uninstall
  3. Go to where you originally saved you ISM Revit Plugin installer and run the installation. The commands will be added to all supported versions of Revit on your machine.
If you no longer have the installation on you machine you can download it from the Bentley iWare website. Bentley iWare
Integrated Structural Modeling Home
