Applies To | |
Product(s): | AutoPIPE |
Version(s): | ALL; |
Environment: | N/A |
Area: | Modeling |
Original Author: | Bentley Technical Support Group |
Date Logged & Current Version | Dec. 2016 10.01.00.09 |
What are typical settings for seabed piping and riser on offshore underwater / subsea piping using AutoPIPE?
Typical hydrodynamic data defined for the seabed piping including non-zero lift coefficient.
Typical Hydrodynamic data defined for the riser, zero lift coefficient
Model Subsea (Underwater) Piping
