The location of Baffles depends on the location of the Nozzle Inlet.
When you move the Nozzle then the baffles move too.
If you delete the Nozzle Inlet and then recreate a Nozzle Inlet, you just have to reset/compute the baffle layout (see Longitudinal view in Bundle Dialog)
