| Product(s): | STAAD Foundation Advanced | ||
| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | General | ||
| Subarea: | N/A | ||
I have got a large number of load cases and combinations in my STAAD Foundation Advanced model. Is there a way for me to quickly set the Load Case Type data to Service and Ultimate for these load cases and combinations
In STAAD Foundation Advanced Connect Edition Update 2 ( 8.2.0.30) and up, you can easily set the Load Case Type for a batch of load cases or combinations.
The process is listed below
The Load Case Type for all selected load cases ( or combinations ) will be set accordingly.
