| Product: | RAM Concrete | ||
| First Affected Version: | |||
| Found in Version: | 15.03.00 | ||
| Fixed in Version: | 15.06.00 | ||
| Area: | Design | ||
| Issue #: | 624602 |
In the joint capacity checks for SMF concrete columns, the program uses the moment capacity associated with the lowest axial force from all load combinations. This can be unconservative, however. For cases where the factored axial force is always large, the largest factored axial load will yield the lowest nominal moment capacity.
This issue has been corrected in v15.06.00 and later.
