12. How to model piping connected the end of a tank / vessel in AutoPIPE?
Product(s):AutoPIPE
Version(s):All
Area: Modeling
Date Logged
& Current Version
Feb. 2016
10.00.00.10
Problem:
There are various types of end connections on Vessels and Tanks:
The technique is the same regardless of the Vessel's / Tanks's end type head construction. However there are 3 modeling approaches.
1. Consider the Vessel / Tank piping connection as an Flexible / Rigid anchor
2. Take credit for the flexibility in the tank construction, insert a Nozzle component then anchor element
3. Model the entire vessel / tank, add piping to surface with rigid piping
See the following procedure and choose one or more techniques to use in your model:
1. Use an Anchor Element
Assume the piping connection to the tank / vessel is considered an anchor component. Insert an Anchor element as needed.
2. Insert Nozzle Element and then Anchor element
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches> Nozzles
Hear are 2 examples of connecting piping to a tank / vessel using a nozzle element.
3. Model the entire tank / vessel
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches> Vessels
Note: in order to connect a pipe at B02, follow the techniques in option #2 above (omitting the anchor of course)
Examples:
1. Connect multiple pipes to end cap
Click here
2. Connect pipe to bottom of tank conical end
click here
3. Connect pipe to Equipment
Click Here
 Modeling Vessel / Nozzles
