| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | Footing Design | ||
| Original Author: | Suvadeep Acharjee, Bentley Technical Support Group | ||
Please clarify the footing type “on raft” given in RCDC.
RCDC designs the isolated footings. The purpose of this options is to maintain the same thickness of first step for all footings if all footing are connected by common raft. This type of footing mostly use in the basement structures. The concept of this type of footing is similar to stepped footing.
