Applies To | |
Product(s): | AutoPIPE Vessel |
Version(s): | ALL |
Area: | General |
Date Logged & Current Version | Nov 2023 44.00.00.111 |
Factor K and required thickness calculations are not matching with manual calculations in limpet coil on Heads, Why?
In limpet coil, calculations of factor K is performed with respect to ASME Section VIII Div. 2 Clause 4.11.6.4.
Find below snap of code for reference.
ASME Section VIII Div. 1 and Div. 2 gives same set of information.
But ASME Section VIII Div. 2 has no limitations on the vessel diameter and Factor K can be calculated with numerical formula without any graph.
Hence, AutoPIPE Vessel calculates with respect to ASME Section VIII Div. 2.
