From time to time something will happen where AutoPIPE may display a message pop-up text box. Most of these typical warnings are categorized by the text box labels below, select the hyper link to see detailed information about each of these different message types:
Issues that Occur when... |
If your message is not found in these categories, please contact technical support and log your issue. Be sure to include your model archive APC file and exact steps to reproduce the error message.
See the following document for typical "Windows System Error Codes (exit codes) Description".
