B. As Per ASME Section VIII
External Pressure Calculation As Per ASME Section VIII, Div. 1
Calculate the test pressure and allowable stress for hydrotest case
Values of modulus of elasticity and factor B are not correct in External Pressure calculation
'Apply ASME UG-23(d) (20%)' option
Flange calculations as per UG-44?
Minimum Design Metal Temperature (MDMT) – ASME Calculation
Body flange according to ASME VIII, div 1: rigidity criterion
Head Thickness Calculations as per ASME Section VIII Div. 1
C-factors derivation as per UG-34
Calculate Corrosion Allowances as UG- 45 or ASME VIII div.1
Axial Loads (f1 & f2) on conical sections per ASME Section VIII Div 1, Appendices 1-5 and 1-8
Calculation of Flange diameter with specified tolerance and corrosion settings
Vertical force is considered as 0 if the SDS is greater than 0.125 as per ASMC 7-16
Factor K and required thickness calculations are not matching with manual calculations in limpet coil on Heads
Area available at outward nozzle weld (A41) is not calculated correctly
Calculations
Support Solutions & FAQ's
Bentley AutoPIPE Vessel
